November 14, 2008, 04:33 |
Turbulent flow + VOF
Hi All i'm interested in turbulent flow + VOF + moving object. volume flow rate for my case is ~ 100cm/s. So does anyone have best general guideline on solver settting? my experice with turbulent model is it always limited by explicit viscous solver as current v9.3 doesn't allow implict solver with turbulent flow.
Rgds CK |
November 16, 2008, 01:07 |
Re: Turbulent flow + VOF
CK,
turbulent viscosity should not limit the time step size since tubulence is only secondary to the mean flow. If it does, it means that turbulence gets out of hand. Make sure you define the turbulent mixing length which should be 7% of the length scale of the main turbulence-producing object in the flow. Michael |
January 13, 2009, 07:29 |
Je m'appelle Melle KHERBACHE KHADIDJA et je suis une étudiante en deuxième année Magistère en Hydraulique à l'école nationale polytechnique en Algérie, Je suis entraîne de faire projet , et j'ai pas trouvé une documentation , alors je vous demande s'il vous plait Monsieur de m'envoyer la decumentation sur la turbulence et la méthode de VOF si c'est possible sur mon Email.
January 13, 2009, 07:30 |
CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 07:08 |
reversed flow at pressure inlet and turbulent viscosity is limited.... | cfdiscool | FLUENT | 10 | June 10, 2015 06:15 |
spectrum: LES of a turbulent channel flow finally goes to turbulent | liu | OpenFOAM Running, Solving & CFD | 6 | November 1, 2011 01:00 |
Air-water flow (VoF). Need help :( | Luke1984 | FLUENT | 6 | October 19, 2009 09:59 |
Turbulent steady flow around a circular cylinder | Mirek Kabacinski | FLUENT | 0 | July 23, 2003 18:40 |
