Home > Forums > Software User Forums > FLOW-3D
Mesh boundaries for waves
Old   December 4, 2008, 17:31
Default Mesh boundaries for waves
aginor
i am using the v9.3 flow 3d. i am using the wave boundary from the one site and the outflow from the other. the water volume is always be less. the water is going out of the outflow and doesnt come in from the wave boundary. so the water height after some wave periods is zero. whats the Wrong??
Old   December 5, 2008, 00:29
Default Re: Mesh boundaries for waves
michael barkhudarov
Aginor, do you see any waves at all?
Old   December 5, 2008, 03:50
aginor
yes! the waves are correct!
Old   December 6, 2008, 00:32
michael barkhudarov
Hmmm. What if you try a pressure with the fixed free surface height, instead of the outflow BC? How many wave periods are you simulating?
Old   December 6, 2008, 17:47
aginor
i try this also. but when the height from the wave as less than the initial i had a huge inflow!! i solve the problem by enable the allow reverse flow fanction!
Old   December 7, 2008, 00:34
michael barkhudarov
Good idea, Aginor. That's exactly what this function is for.
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 08:07
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 00:27
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 04:08
