-   FLOW-3D (http://www.cfd-online.com/Forums/flow-3d/)
-   -   Surface roughness in Flow-3d (http://www.cfd-online.com/Forums/flow-3d/27312-surface-roughness-flow-3d.html)
Marco December 23, 2008 10:28
Dear experts :
In open channel, roughness coefficients are typically in one of two ways: (1)Chey's resistence coefficient, or(2)Manning's n. But in flow-3d, the roughness coefficients is use k (be expressed in unit of length).
So, flow-3d's roughness and open channel's roughness is different. I want to know how did I define the surface roughness if I simulated open channel flow. Did Manning's n necessary translate to roughness K by some equation or another methods?
May someone provide the opinion for me? Thanks your help!
Jorge D. Abad December 23, 2008 13:40
Re: Surface roughness in Flow-3d
Marco, I will suggest to take a look into Yen's book. The roughness (rough) in F3D is a Nikuradse type of roughness (ks), then, if you have values of Manning you can use the following equation:
ks[m]= (n[m^(1/6)]/0.0389)^6
where m is meters and n[m^(1/6)] is usually the values 0.030 (riprap) found in Open channel textbooks ==> ks=0.21039.
Remember Manning n above has units of m^(1/6). Further details read Yen's book.
Good luck
Jorge D. Abad
REFERENCE: Yen, Ben Chie (1991). "Channel flow resistance: centennial of Manning's formula:. Water Resources Publications.
Marco December 23, 2008 22:12
Jorge D. Abad, very thanks your help!
So, I know manning value. And I use equation [ ks[m]= (n[m^(1/6)]/0.0389)^6 ] that I can get a ks value. Then input the surface roughness (ks) of surface properties in flow-3d. Did I solve roughness problem ?
Thanks you to provide the reference for me.
