Inkjet Simulation using Elastic Membrane Modeling |
January 11, 2009, 22:44 |
I was trying to simulate a piezoelectric inkjet ejection using the elastic membrane modeling (Flow3D V9.3). I have followed closely to the Microfluidics Tutorial to create the required prepin file as follow. ************************************************ &xput remark='units are SI', twfin=50e-6, itb=1, gz=9.8, imemb=1, imobs=1, ifsft=1, ifvisc=1, delt=1e-9, dtmax=1e-7, dtmin=1e-50, imp=2, ihelp=2, lpr=3, hpltdt=0.0, pltdt=1e-6, / &limits / &props rhof=1000., sigma=32e-3, units='si', mu1=15e-3, / &scalar / &bcdata wl=2, wr=2, wf=2, wbk=2, wt=3, / &mesh nxcelt=150, px(1)=-150e-6, px(2)=150e-6, nycelt=150, py(1)=-150e-6, py(2)=150e-6, nzcelt=50, pz(1)=0.0, pz(2)=100e-6, / &obs avrck=-3.1, nobs=2, tobs(2)=2e-1, tobs(3)=2.1e-1, iob(1)=1, xl(1)=-150e-6, xh(1)=150e-6, yl(1)=-150e-6, yh(1)=150e-6, zl(1)=0., zh(1)=5e-06, imb(1)=2, imbe(1)=1, imbn(1)=3, xmbw(1)=100e-6, ymbw(1)=16e-6, zmbw(1)=2e-6, xfmbw(1)=80e-6, yfmbw(1)=13e-6, rpmbw(1)=0.4, embw(1)=190e9, rhombw(1)=7850., fmbw(1,1)=3e5, fmbw(2,1)=3e-5, xcmbw(1)=0., ycmbw(1)=0., iob(2)=2, iob(3)=2, ioh(3)=0, xl(2)=-150e-6, xh(2)=150e-6, yl(2)=-150e-6, yh(2)=150e-6, zl(2)=0., zh(2)=30e-6, zh(3)=3e-05, trnz(2)=60e-6, zl(3)=0., rah(3)=15e-06, trnz(3)=6e-05, iob(4)=2, ioh(4)=0, zl(4)=0., zh(4)=40e-6, coneh(4)=35., rotx(4)=180.0, trnz(4)=95e-6, imbe(2)=1, imbn(2)=3, rambw(1)=140e-6, rfmbw(1)=135e-6, famp(1)=1e-3, freq(1)=100., / &fl flht=90e-6, / &bf / &temp / &motn / &grafic / &HEADER PROJECT='InkJet_Rev1', / ************************************************** *** I have been encountering the following errors: * Pressure iteration diverging * Result in excessive pressure convergence failures. I have tried the followings: 1. Enable the implicit automatic limited compressibility mode. 2. Using GMRES 3. Reduce the step time to 1e-25 4. Increase the maximum number of iterations. 5. Reduce to the applied force to very small. I am clueless why the simulation is not working. Any suggestion!!!! Best regards, Raju |
January 14, 2009, 10:35 |
Re: Inkjet Simulation using Elastic Membrane Model
Hi Raju,
Try turning off automatic limited compressibility and the mentor, i.e., set IMP=1 and IHELP=1. Are you using implicit coupling between the membrane and fluid? I think this may be the default. Also, you may look at the "micro-pump" example provided with the installation, which uses the membrane model, for clues. If all does not work I suggest contacting support for a closer look. Michael |
What is Multi Scale Modeling and Simulation | rt | Main CFD Forum | 0 | January 30, 2007 08:11 |
simulation or modeling of mans mind | han | Main CFD Forum | 7 | December 14, 2005 15:17 |
simulation on pulsatile flow in elastic conduit | pratyush rai | Main CFD Forum | 0 | December 13, 2005 03:25 |
Fire simulation using FDS from NIST | Jens | Main CFD Forum | 1 | January 22, 2004 01:53 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 10:06 |
