-   FLOW-3D (http://www.cfd-online.com/Forums/flow-3d/)
-   -   how to view the complete results (http://www.cfd-online.com/Forums/flow-3d/27338-how-view-complete-results.html)
shokry January 29, 2009 05:00
hi all When i simulate the program to get a a result each 10 seconds the results apear up to some time then no results apear after that while the simulation complete to the end so if I run to 120 sec the results apear at 10,20,30,....tofor example 70 and then no results apear while the simulation run to the end can any body help me
HC January 29, 2009 13:50
Re: how to view the complete results
Is the disk full? or could you post the xput namelist?
shokry January 29, 2009 14:11
thanks for your reply the capacity of the hard is ok but the problem is solved after deleting all the files in the folder except prepin.inp and flsgrf.dat and i don't know why
AC February 3, 2009 13:25
What version of flow3d are you running?
shokry February 3, 2009 14:47
v 9.2
AC February 3, 2009 14:56
This does not seem to happen with V9.3, can you upgrade?
