August 29, 2011, 18:40 |
final result
Rep Power: 14 |
hi
When the software gives me the final result? How much time should I put for my software? when should I stop it? thanks |
September 1, 2011, 08:03 |
Marcin
Rep Power: 15 |
The answer to that question is not easy. You have to know what kind of simulation you want to run, than you need to analyze physical models, initial condition, one more time think about results you want to observe, than ask. Best regards. |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 12:53 |
