-   FLOW-3D (http://www.cfd-online.com/Forums/flow-3d/)
-   -   Vectors (http://www.cfd-online.com/Forums/flow-3d/63483-vectors.html)
a.etesam April 9, 2009 13:42
Vectors
Hi to evry body
in F3D 9.0 in analyze tab in 2D does Rubber Band area work? How does it work. I want to see the vectors in 2D clearly. is that possible?;):)
melissa April 9, 2009 17:42
Hi~
From the display you should be able to check the box then use the mouse click and drag to opposite corner then you can output the file as a bmt and it will only output the selected region. If you want to you can make your velocity vectors larger by selecting format in 2-D panel and resize them. Hope this helps. :D
a.etesam April 10, 2009 01:41
Hi melissa
Thank you very much i try to reach to that i want. but i have a qustion in F3D 8.2 Savage & Bruce could compute the discharge. yet i really dont know that how can i find the discharge.Thank you so much melissa:)
