data point
Hi every body
I use F3D 9.0. I should know pressure & velocity of many points with certain coordinats. but i dont know how do that? can you help me?:confused::confused::confused::confused::confus ed: |
try neutral file.
Data point
Hi H.C
I have a warning in neutral file:No coordinate state file( transf.in),can not creat neutral file. what should i do? do you know i want to compute pressure and velocity in certain point that has coordinate such as A(x1,y2,z3),B(x2,y2,z2)........ thank you so much:) |
make sure the file "transf.in" is in the simulation directory. sometimes users might forget to remove the old extension such as txt. in "transf.in", please add the following lines
-1 0 x1 y1 z1 x2 y2 z2 .... |
