How did I output discharge data ?
Dear Flow-3d expert :
I simulated a channel in flow-3d. I want to see discharge data at the last cross-section. How did I set in flow-3d ? I can see the mesh depended history data of right, left, front, and back boundary fluid 1 volume flow rate in '' Analize->Probe->Mesh depended history->Text(Graphical) "'. Were that discharge data? I am confused . Thanks your help, regards. |
Flow rate is another name. :-)
Thanks for Ghirghidov.
So you mean that volume flow rate is not discharge data, didn't it ? |
I mean volume flow rate is discharge data for border.
Ok, I see.
Then, do you know how can I output discharge data at last cross-section ? Because, governing equations don't have "flow rate term". I have an idea that output velocity data. Then velocity multiply to mesh area that is volume flow rate. How did you think ? |
If the boundary volume flow rate is not enough you are right (IMHO you have to exclude solid parts from the mesh area but sometimes it's quite difficult)
