flow of oil
Hi all!
I would like ask You about simulation - flow of oil through the filter in FLOW3D. Can we simulate it? How Can I describe material properties for filter? This is some kine of fibrous material. Regards north http://www.cfd-online.com/Forums/C:%...op%5Cwlot2.jpg http://www.cfd-online.com/Forums/C:%...top%5Cwlot.jpg |
North
this is doable by using Porous Medium option to simulate the flow resistance through filer. With porous medium option you need to calculate both drag coefficient a & b based on your filter pore size. hope this help. |
Hi ck5285,
thank you for the reply! please look on the screens... http://picasaweb.google.pl/north.no/Filtr#http://picasaweb.google.pl/north.no/Filtr# What kind of value (for ADRG and BDRG) should I use to simulate filter? You wrote that it depends from the pore size. But this pores are really small. thanks in advance north |
north
the image attached may not clearly show the filter shape or design, anyway you can refer to link below from Flow-3D on how to calculate drag coeff a & b as below. http://www.flow3d.com/resources/news...ring08_06.html |
Hi ck5285,
thanks for link to flow3d resources! Now it is clearly for me! |
