July 17, 2009, 04:09 |
flow of oil
Hi all!
I would like ask You about simulation - flow of oil through the filter in FLOW3D. Can we simulate it? How Can I describe material properties for filter? This is some kine of fibrous material. Regards north |
July 17, 2009, 22:30 |
North
this is doable by using Porous Medium option to simulate the flow resistance through filer. With porous medium option you need to calculate both drag coefficient a & b based on your filter pore size. hope this help. |
July 20, 2009, 04:30 |
Hi ck5285,
thank you for the reply! please look on the screens... http://picasaweb.google.pl/north.no/Filtr# What kind of value (for ADRG and BDRG) should I use to simulate filter? You wrote that it depends from the pore size. But this pores are really small. thanks in advance north |
July 20, 2009, 20:45 |
north
the image attached may not clearly show the filter shape or design, anyway you can refer to link below from Flow-3D on how to calculate drag coeff a & b as below. http://www.flow3d.com/resources/news...ring08_06.html |
July 22, 2009, 05:40 |
Hi ck5285,
thanks for link to flow3d resources! Now it is clearly for me! |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
Lubricant oil, two phase flow | Rikio | CFX | 0 | December 30, 2008 21:08 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 13:11 |
How to change from mass flow to volume flow rate | stanley | FLUENT | 1 | February 2, 2007 06:44 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 08:42 |
