-   FLOW-3D (http://www.cfd-online.com/Forums/flow-3d/)
-   -   Absolute pressure (http://www.cfd-online.com/Forums/flow-3d/66552-absolute-pressure.html)
meysami July 18, 2009 09:17
Absolute pressure
Would you please tell me how can define a absolute pressure in fluid?
because, when I simulate a free surface and define a void pressure in top area, a logical hydrostatic pressure does not form. I am modeling bubble formation on a hot rod, also I active cavitation model.
best regard
stefmascio July 20, 2009 10:14
if you are using the gravity, and you set an initial pressure with absolute values, then you'll have in your calculation absolute values of pressures.
meysami July 21, 2009 02:55
Dear Stefano
Thank you very much for your answer.
I set gravity and initial pressure with absolute valie, but the pressure was very variable during solving. would you please tell me where are there any mistakes? I must tell you that I have active bubble phase change mode in this calculation
best regards
stefmascio July 21, 2009 04:13
hello meysami,
it is hard to understand what happens in your simulation. I would need more informations. But you can start to look in the online manual, at the chapter "How do I model", to check if you are modeling the bubble with all the data needed or if something is missing.
meysami July 21, 2009 05:21
Dear Stefano
Thank you very much. For bubble modeling I have checked every thing many times, but unfortunately I have not gotten correct answer and the pressure varies during calculation, I do not understand why pressure is variable, if possible for you I can send my perpin file to you via email. I will very pleasure that you help me for solving this problem. I am waiting your answer
Best regard
stefmascio July 21, 2009 05:37
if you use the bubble model then it is right that the pressure changes: it will change following the equation of state of the gas.
