Home > Forums > Software User Forums > FLOW-3D
Stl Model and Model after preprocessor are not the same !!!
Old   September 22, 2009, 11:34
Red face Stl Model and Model after preprocessor are not the same !!!
Attapon
AttaponC is on a distinguished road
http://img97.imageshack.us/i/model.jpg/
http://img2.imageshack.us/i/preprocessor.jpg/
Hi everyone
I 'm try to learning flow-3D.
I modeled like a flow from weir.
And I found problem.
After I did preprocessor the solid model has been changed.
Somes wall of them disappeared. And I tried to run simulation.
And the result showed that there was no that wall.
Please see picture for more detail.
Could anyone guide me what I have done wrong......
Thank in Advance
AttaponC is offline   Reply With Quote
Old   September 24, 2009, 13:05
ck5285 is on a distinguished road
Hi Attapon
I believe the wall presented here is a thin wall right? so, I suspect your mesh is not fine enough to resolve the solid wall eg: solid object needs a least 2 cells a long the thickness for good meshing. So, you may need to use fix point to ensure you have at least 2 cells along the thickness of thin wall object. Hope this help.
ck5285 is offline   Reply With Quote
Old   September 30, 2009, 23:54
michael barkhudarov
MuxaB is on a distinguished road
Attapon, did you figure it out? Was it poor mesh resolution?
MuxaB is offline   Reply With Quote
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 07:15
references about the fan/radiator model Mihai ARGHIR Main CFD Forum 1 January 8, 2001 15:49
references about the fan/radiator model Mihai ARGHIR Main CFD Forum 0 December 21, 2000 03:06
references about the fan/radiator model Mihai ARGHIR Main CFD Forum 1 December 17, 2000 07:01
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
