Home > Forums > Software User Forums > FLOW-3D
No sharp interface - Discharge in a pipe
Old   October 21, 2008, 08:35
Default No sharp interface - Discharge in a pipe
Matthieu Breysse
Hello dear users,
I am trying to calculate a discharge in a pipe with a fixed pressure and flow. What are the best boundary conditions at the entrance section and the exit section (that is to say at the begining and at the end of the mesh)? When I impose the velocity at the begining and at the end the pressure field don't stabilize and I also get negative pressure. What is the best limit condition to impose on this problem ?
Thanks for helping me.
Matthieu
Old   October 21, 2008, 11:07
Default Re: No sharp interface - Discharge in a pipe
HC
I assume you meant that you got pressure iteration failures by saying the pressure filed don't stabilize. For that problem, you may need to check the mesh, or increase the maximum number of iterations, or use a bigger GMRES subspace size, e.g. 15, if GMRES pressure solver is applied. You may also need to use a small initial time step.
As you used velocity boundary conditions at both inlet and outlet, there was no reference pressure given in the domain and the pressure result you got would just be gauge pressure. So a negative pressure in that case would be ok.
A typical boundary set for pipe flow would be velocity/volume flow rate inlet and fixed pressure outlet (as you mentioned).
Old   October 21, 2008, 23:46
Michael Barkhudarov
Matthieu,
Having velocity at both ends of the pipe is overspecifying the problem. This causes pressure convergence problems and unphysical pressure values. Do you get a message from the mentor about a net in/out flow in the domain?
Having velocity at one end, e.g., inlet, and pressure at the other should do the trick.
Michael
Old   October 22, 2008, 12:09
Matthieu Breysse
Thanks for your advice, I put the same simulation with the velocity at the entrance section and the continuative condition at the exit section and it is working.
Matthieu
Old   October 23, 2008, 09:26
Michael Barkhudarov
Glad to hear this, Matthieu.
Old   December 10, 2009, 21:18
Default Please help me
Yi-Lang Chen
Andy Chen is on a distinguished road
Originally Posted by Matthieu Breysse
;92798
Matthieu
Could you help me to solve no sharp interface problem? I simulated no sharp interface that was pipe flow. But my pressure can't convergence. My inlet boundary is specific velocity and oulet boundary is specific pressure. But oulet domain was occuring backwater taht was wrong. Please help me~ thanks.
Andy Chen is offline   Reply With Quote
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
measured pressure in the discharge pipe jumps Jan Main CFD Forum 1 October 30, 2006 07:54
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
