-   FLOW-3D (http://www.cfd-online.com/Forums/flow-3d/)
-   -   two fluid (http://www.cfd-online.com/Forums/flow-3d/72263-two-fluid.html)
great1427 January 31, 2010 02:00
two fluid
Hi, everyone!
I have a question about Flow 3D.
If i want to design a model for two fluids, A and B.
The initial condition is that A fluid is all in the tank.
The inflow is B, and how to do to set Q and H.
thanks your help.
MuxaB February 1, 2010 00:40
Is Q the flow rate? What is H?
great1427 February 1, 2010 05:27
Q is flow rate.
H is fluid height.
MuxaB February 1, 2010 10:19
fluid A is below H and fluid B above? Is Q the flow rate of fluid B? no fluid A is entering at the boundary, right?
great1427 February 1, 2010 11:15
the A fluid and B fluid are the same height.
the A fluid is like a reservoir.
the B fluid is like sediment flow. And the boundary is B's flow rate.
No A fluid enter at the boundery.
thanks a lot.
MuxaB February 1, 2010 23:46
thanks a lot.
How can you have sediment fluid B flow without fluid A?
In any case, you can define both fluid height and flow rate at an x or y mesh boundary using the flow rate BC. If you are using the two-fluid model, then the fluid fraction at the boundary controls the A/B mixture: F=1 - fluid #1 (A), F=0 - fluid #2 (B). If you use the sediment scour mode instead, then you can define the sediment concentration at the boundary directly. In that case, sediment is not treated as fluid, but rather as a concentration of sediment in fluid #1.
great1427 February 3, 2010 22:46
And i have a question.
how about to set the mass source?
If i want the B fluid that is salt flow,then i have to set the model that is fluid 2,right?
however, i don't kown how to set the Mass-moment sources and Mass sources.
if you can, give an example.
thanks a lot.
