-   FLOW-3D (http://www.cfd-online.com/Forums/flow-3d/)
-   -   Pile scouring (http://www.cfd-online.com/Forums/flow-3d/72400-pile-scouring.html)
hans_ina February 4, 2010 09:47
Pile scouring
Dear All,
I should modeling scouring around cylinder pile, but i have problem with depth of sediment(soil) i cant find where the input for the depth of soil and B.C at boundaries tab for input.
thank so much!
Ghirghidov February 4, 2010 10:04
That is not there. it's in the Initial for fluid 2
hans_ina February 4, 2010 19:47
dear Ghirghidov,
you mean fluid region? i have add fluid region and add value for suspended sedimentation but after run simulation there is no sediment elevation.
Or you mean, i have to definition for 2 fluid region?
thank you
Hans
Ghirghidov February 5, 2010 11:47
Dear Hans.
Yes that's exactly what I mean but in postprocessing you have to check out SS as concentration. Unfortunately you will not be able to see river bottom (for example). :-(
hans_ina February 5, 2010 21:34
dear Ghirghidov,
I use F3d 9.3, i can see the sediment as packed sediment concentration and my problem now is why all sediment are uplift in all areas, not around circular piles? i use 1m/s velocity for 0.6m diameter piles. Am I wrong in boundaries?
Ghirghidov February 8, 2010 06:22
I am not sure that using velocity boundary is correct. I believe you have to use water level (pressure) at boundaries.
Regards.
cdf_roli March 15, 2010 09:58
Hi hans_ina
In FLOW-3D Version 9.4 you have define a componment or you input a stl-file.
Then you can edit the componment proporties to "packed sediment".
greats
CFD_roli
pourahmadiii April 6, 2010 02:53
hi
i must medel scour around bridge can any one help me?
i need a help for using flow 3d v 9.3
