Home > Forums > Software User Forums > FLOW-3D
Ocean simulation
Old   March 1, 2010, 09:02
Default Ocean simulation
Kuan Jew Xun
njyugikjxun is on a distinguished road
i am doing simulation on ocean... it required a lot of complicated geometry setup which i am not so familiar. can anyone guide me or give me some tips?
the sample ocean model will be taken part on south china sea. is it depth of ocean must include in consideration? and how i gonna to draw the part of the land near the ocean?
thanks and appreciate if you help and reply me
njyugikjxun is offline   Reply With Quote
Old   March 1, 2010, 09:28
Armen A. Ghirghidov
Ghirghidov is on a distinguished road
Dear Kuan Jew Xun.
I believe the Shallow water model will be good enough. I don't know about your task but I think it has area is about a few kilometers and water depth is about meters, so SW will be the best one. In this case you shoud have quite good computer. :-)
Regards, Ghirghidov.
Ghirghidov is offline   Reply With Quote
Old   March 1, 2010, 09:41
Kuan Jew Xun
thanks for your suggestion. by the way, the simulation will cover the area of Sabah, one of the state in Malaysia, which cover few hundred kilometer, while i haven't get the information on water depth. if the location is held near the land area, it might be few kilometer.
the main problem now i have to draw a certain location in Sabah, including the 10% of land and 90% of ocean. but i have no idea how to draw the complicated geometry of Sabah. what say you?
Old   March 2, 2010, 05:36
Armen A. Ghirghidov
Dear Kuan Jew Xun.
As I understood right you could use 3D points topo file made by some other software like Didger (by Golden Software). Sometimes we use Civil (by Autodesk). Ussually we use our own software for digitization map (including onshore and offshore).
Old   March 2, 2010, 05:40
Kuan Jew Xun
Dear Ghirghidov,
Thanks for your help by replying me again... I am going to try this out tonight, i will ask for your help again if i face problem again. mind if you leave me your email address here so i able to contact you easily? is better if you have msn address.
Old   March 2, 2010, 08:16
Kuan Jew Xun
Dear Ghirghidov,
is it the 3D points that we made can be imported to flow3d?
Old   March 2, 2010, 08:40
Armen A. Ghirghidov
Dear Kuan Jew Xun.
Sure. just check the manual or help.
Old   March 3, 2010, 07:28
Kuan Jew Xun
Dear Ghirghidov,
Sorry to bother you again. I asked my senior on how they build the terrain and ocean. They said that we used google earth and google sketchup. I tried to model 3D structure and it end up to save the structure in .kmz format. So is that anyway to convert and import that file to FLOW3D?
Alternatively, I used Autodesk AutoCAD. It able to save the structure to .stl format as FLOW3D need. However, I unable to important the .kmz format to AutoCAD too. Do you have any suggestion for me?
Old   March 3, 2010, 07:44
Armen A. Ghirghidov
Dear Kuan Jew Xun.
What is лья format. Could you send me any file as an example (from GE of course)?
BTW is 3D Object converter able to convert your kmz file?
Old   March 3, 2010, 08:09
Kuan Jew Xun
Dear Ghirghidov,
http://www.esnips.com/doc/7eb17ad0-f...2af5e/Himalaya
You may download the example I tried in Google Sketchup. You have to open it through Google Sketchup. You can download this software at http://sketchup.google.com/
Basically, the model you saw in this example is directly taken from Google Earth. (Ignore this if i confuse you)
Google Sketchup able to convert to dwg format (AutoCAD format) if the version is Google Sketchup Pro. It required activation cost.
I hope it has alternative way to solve. You try this out and let me know soon.
Old   March 3, 2010, 09:07
Armen A. Ghirghidov
Dear Kuan Jew Xun.
First of all. your file is in Chineese. F3D works only with English. :-)
As I understand it right the kmz file is archive. kml - is unpacked. I was not able to convert it to any editable format (autodesk or any other). I'll ask one guy who works with GIS technology.
Reagrds, Ghirghidov.
Old   March 3, 2010, 09:31
Kuan Jew Xun
Dear Ghirghidov,
I am sure that the file is not in Chinese. It should be Himalaya.skp and only able to open up by using Google Sketchup in Google Sketchup, It can be exported to kmz format which is able to open via Google Earth.
I resend the Mount Himalaya 3D structure to your work and personal email. If you unable to view the structure via Google Sketchup, feel free to let me know again.
Also, I wait to hear from your good news
FSI TWO-WAY SIMULATION Smagmon CFX 1 March 6, 2009 13:24
simulation of ocean waves Balaji FLUENT 0 July 1, 2005 02:21
Ocean thermal simulation ckmoied FLUENT 1 June 29, 2004 09:48
ocean simulation Wenqing Zhang Phoenics 3 August 7, 2002 09:36
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 10:06
