February 27, 2010, 05:12 |
thermal boundary option
liang liam
Rep Power: 16 |
hello everyone~
I have a problem about ...heat transfer coefficients that is from model setup/boundaries/mesh boundaries/mesh block/wall/thermal information/thermal boundary options there are heat transfer coefficient to fluid 1 &to fluid 2 ,does anybody know that means? thanks |
February 28, 2010, 19:52 |
michael barkhudarov
Rep Power: 18 |
if the mesh boundary is of type 'wall' with a specified temperature, then it needs an htc between the wall and adjacent fluid to compute the heat flux at the boundary. The user can defined a different htc for fluid 1 and 2 in two-fluid problems.
does it make sense? |
February 28, 2010, 23:55 |
Rep Power: 17 |
Michael
i thought the heat transfer coefficient is calculated by the solver while solving the conjugate heat transfer problem? pls help to clarify. |
March 1, 2010, 11:23 |
michael barkhudarov
Rep Power: 18 |
Yes, the solver will do it if you leave these input entries blank.
March 3, 2010, 10:07 |
liang liam
Rep Power: 16 |
but if I set the 'wall' as copper that have thermal conductivity value(k),does it needs a htc ?
March 3, 2010, 18:27 |
michael barkhudarov
Rep Power: 18 |
It does not really matter what material it is made of. The user can either define a constant htc at the fluid/wall interface, or the code will compute it automatically as a function of the materials properties and the flow. In the latter case, it assumes that the contact between copper and fluid is perfect, i.e., no thermal resistance.
Display Modes | |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
transient simulation of a rotating rectangle | icesniffer | CFX | 1 | August 8, 2009 07:25 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 01:40 |
