-   FLOW-3D (http://www.cfd-online.com/Forums/flow-3d/)
-   -   Micro-porosity (http://www.cfd-online.com/Forums/flow-3d/75382-micro-porosity.html)
jk75 April 23, 2010 10:02
Micro-porosity
Hi All,
I have a solidification simulation with dynamic shrinkage model and microporosity model activated. Shrinkage seems to be ok, but the calculated Microporosity is about 1.E-10. Has someone experience with this combination?
Johannes
MuxaB May 5, 2010 00:03
what version of FLOW-3D are you running? there was a problem like that, I think, in version 9.3, but has been fixed since then.
jk75 May 6, 2010 06:41
I'm using version 9.4.1, running on linux 64bit.
jk75 May 28, 2010 04:28
We have verfied the microporosity issue now with different setups. It's now clear that the micro- porosity is only calculated correctly (in combination with the solving of the momentum equations) when shrinkage is deactivated. That's not good, because we would need dynamic shrinkage AND micro- porosity...
lenken December 11, 2013 10:00
Hi Johannes,
I am Ken, studying in germany. I am currently writing my bachelor thesis with flow 3D 9.4.1 as well. I am simulating solidification process. But I have some problems with the display. It doesn't show shrinkage on display and the temperature variation is illogical and the pressure variation doesn't change at all.
May I know what settings did you make for this solidification simulation?
I do not know where the problem is and i am using copper as my mould and pure iron as my fluid 1.
Thanks a lot first for ur attention and time.
best regards
Ken
