Home > Forums > Software User Forums > FLOW-3D
Memory Utilization with Flow-3D
Like Tree1Likes
  • 1 Post By ck5285
Old   February 11, 2010, 20:31
Default Memory Utilization with Flow-3D
ck5285 is on a distinguished road
All
noticed that by using SMP version the CPU utilization is high (without GMO option turn on) but memory utilization is always low at around 200MB-400MB. so I wonder why the program didn't fully utilize the memory size that my system have (32GB RAM) in order to provide additional speed up in simulation time?Thanks.
ck5285 is offline   Reply With Quote
Old   February 25, 2010, 12:25
michael barkhudarov
MuxaB is on a distinguished road
Originally Posted by ck5285 View Post
All
The memory usage is largely determined by the mesh size and the selection of physical and numerical options. SMP parallelization in FLOW-3D does not add much to this, although it could have been done in a way that would consume much more memory - in proportion to the number of threads used, but this does not seem reasonable.
MuxaB is offline   Reply With Quote
Old   February 28, 2010, 23:50
Michael
so can you advice what physic, solver setting & mesh size will allow full memory utilization? btw, should i expected simulation time speed up if the memory utilization is 100%?
dbz112233 likes this.
Old   March 1, 2010, 11:22
michael barkhudarov
Michael
I am not sure what you mean by 100% memory utilization. Do you want FLOW-3D to use all 32 Gb of memory? If you are asking rather what options have been SMP parallelized, please see this article http://www.flow3d.com/resources/news...fall07_06.html.
Old   May 12, 2010, 03:17
Default re
Seunghyun Yoon
shstyle0 is on a distinguished road
I don't think using more memory would speed up the simulation. memory is like a hard drive, a storage. Using 100% memory would mean you have 32 Gb for your computer to remember, which means your cpu would have more stuff to calculate.
If you use more cells (smaller cells), then your memory usage would go up, but the calculation time will be much longer I believe.
shstyle0 is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
What is the difference between liquid reactive flow and gas reactive flow? James Main CFD Forum 6 May 15, 2009 12:14
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 07:40
Plug Flow Franck Main CFD Forum 3 September 4, 2003 05:57
