About Cooling channel
Hello, all.
I am trying to simulate a casting process with a cooling channel. the geometry is simple, rectangular mould with a cylinder cavity, and a cooling channel is set outside of the cavity. The mould is set as "solid", the cylinder cavity and cooling channel are set as "hole". Then I add a "void point" in "Model setup->initial" with constent temperature as illustrated in the manual, and the the coordinate of the void point is inside of the cooling channel. However, the results show that the cooling effect is applied on the cylinder cavity, not on the cooling channel! which can be found through iso surface "conplement of fluid fraction". I have tried to change the coordinate of the void point along the cooling channel, but the effect is same. If there anyone familar with similar problem, please help me! FYI, the input file is as follows, Title This is a sample input file $xput remark='units are ...', twfin=100., itb=1, ifenrg=2, iwsh=0, ihtc=2, ifsld=1, iedt=2, pltfrc=0.05, delt=1e-6, imphtc=1, hflv1=0.0, $end $limits $end $props rhof=2437., rhofs=2680., cv1=1194., cvs1=963., thc1=116.8, thcs1=152., clht1=3.89e+05, ts1=539.6, tl1=615.9, tniyam=-1., tsdrg=1., mui=0., mu1=0.0012, muc00=0., muc0=1., muc1=0., muc2=0., muc3=0., muc4=0., mutmp1=0., mutmp2=0., mutmp3=1., muthk=0., muthn0=0., muthn1=0., teut=0., cexf1=0., cstar=0., dratio=0., pcoef=0., fluid1='Aluminum Alloy A357', units='SI', $end $scalar $end $bcdata wl=2, wr=2, wf=2, wbk=2, wb=2, wt=5, pbct(1,6)=243.7, tbct(1,6)=620., tbct(1,1)=294., hwall1(1)=0., hwall2(1)=0., hwobs(1)=-1., tbct(1,2)=294., tbct(1,3)=294., tbct(1,4)=294., tbct(1,5)=294., $end $mesh nxcelt=35, px(2)=0.8, nycelt=35, nzcelt=40, pz(2)=1.5, px(1)=-0.8, py(1)=-0.8, py(2)=0.8, pz(1)=-0.4, $end $obs avrck=-3.1, nobs=1, iob(2)=1, ioh(2)=1, xl(2)=-0.8, xh(2)=0.8, yl(2)=-0.8, yh(2)=0.8, zl(2)=-0.4, zh(2)=1.5, magnx(2)=1., magny(2)=1., magnz(2)=1., subcmpid(2)='Rectanguar', material(1)='Steel H-13', twobs(1,1)=294., kobs(1)=28.6, rcobs(1)=3.5618e+06, hobs1(1)=20000., hobs2(1)=-1., ocang(1)=90., obsid(1)='Moud and cavity', subcmpid(3)='Cylinder', iob(3)=1, ioh(3)=0, zl(3)=0., zh(3)=1.5, rah(3)=0.4, magn(3)=1., magnx(3)=1., magny(3)=1., magnz(3)=1., rotx(3)=0., roty(3)=0., rotz(3)=0., trnx(3)=0., trny(3)=0., trnz(3)=0., hobv1(1)=928.6, hobv2(1)=0., hobv3(1)=0., iob(6)=1, ioh(6)=0, cc(6)=0.201875, crxy(6)=-0.9, cx2(6)=1.0, cy2(6)=1.0, cz2(6)=1.0, magn(6)=1., magnx(6)=1., magny(6)=1., magnz(6)=1., rotx(6)=0., roty(6)=0., rotz(6)=0., trnx(6)=0., trny(6)=0., trnz(6)=0.75, subcmpid(6)='Cooling', $end $fl xvr(1)=0., yvr(1)=0.45, zvr(1)=0.75, tvrd(1)=1., ivht(1)=1, pvrd(1)=0., fioh(1)=1, $end $bf $end $temp $end $motn $end $grafic $end &HEADER PROJECT='Copy of Rectangular', / $parts $end Documentation: general comments, background, expectations, etc. #start tables: #end start tables |
It is so strange, I just build a new workspace and do it again exactly like abbove, the cooling channel works!
