-   FLOW-3D (http://www.cfd-online.com/Forums/flow-3d/)
-   -   Maximum and minimum Values (http://www.cfd-online.com/Forums/flow-3d/77145-maximum-minimum-values.html)
me.ouda June 14, 2010 17:20
Hello friends
I am using flow 3d 9.3.2 to simulate wave transportation under floating breakwater
i need to plot the free surface
but as you know the surface height is variable with time in wave problem so i need to plot only the crest hights (maximum values) and the trough values (minimum values) at specific point
how could i do this
MuxaB June 20, 2010 19:11
Originally Posted by me.ouda (Post 262976)
Hello friends
how could i do this
What you could do is, first, request the hydraulic data output, which includes the free surface height, then place a probe at the location where you'd like to record the free surface elevation. The x and y location of that point are important, z is not and can be anywhere within the mesh. The result will be the free surface elevation as a function of time (in the general history data output). You can then extract the highest and lowest elevations from that data series.
ck5285 June 23, 2010 01:28
Michael
seem like it is not a straight forward way. so any improvement on this for v9.5 to ensure it is easy for user?
MuxaB June 24, 2010 02:14
no, not really. Do you have a suggestion on how to generalize or automate it?
