-   FLOW-3D (http://www.cfd-online.com/Forums/flow-3d/)
-   -   Wind Tunnel (http://www.cfd-online.com/Forums/flow-3d/79303-wind-tunnel.html)
kaje August 19, 2010 06:35
Wind Tunnel
Hi all,
How to make a wind tunnel?
i want to simulate a rotating blade..
please advise..
Thank you in advance for your help
MuxaB August 27, 2010 00:04
There are a couple of models available for a rotating blade. The GMO model can give you a very detailed solution, but may be slow, especially if you are modeling many revolutions. In that case, you can use the fan/impeller model which averages the effect of the blades over the volume they cover in space and applies an momentum source to the fluid rather than a boundary condition from a moving GMO. This is a very efficient model for modeling many revolutions of an impeller. The model can be refined by including the effects of blades.
The details of each option are in the manual.
