July 29, 2010, 11:50 |
Does the variable 'nbl' have an upper limit?
Yang Yue
Rep Power: 16 |
Hi fellas,
I think the variable 'nbl' is used to define the number or sequence of the mesh blocks in Flow-3D. But I cannot find the definition of it in the help file. I used more than 5 mesh blocks in my simulation, but the nbl only has a rage from 1 to 5 in the output. I didn't give it a limit in my code. Does it have an upper limit defined in Flow-3D orginal code? Thanks a lot! Yang |
September 2, 2010, 22:55 |
michael barkhudarov
Rep Power: 18 |
The limit for the number of mesh blocks is 500, and it is only set in the post-processor; the solver does not have that limit.
Are you customizing the solver? |
September 3, 2010, 05:35 |
Yang Yue
Rep Power: 16 |
Yes, currently I'm using a customised code to tracking the surface entraiment during fill of casting mould. There are still some variables that I cannot understand in the customisation.
Can Flow-3D calculate the six different velocities of the face centres in one element (mesh cell)? or it only has one value, i.e. one velocity in the body centre of the element? Thank you! Yang |
September 4, 2010, 11:53 |
#4 | |
michael barkhudarov
Rep Power: 18 |
September 6, 2010, 05:47 |
Yang Yue
Rep Power: 16 |
Thanks, Michael.
I just checked the manual. It mentions that the u(ijk), v(ijk) and w(ijk) is the velocities at right, back and top faces respectively, that means the velocity at the left face of cell (ijk) is represented by the velocity at right face of cell (imjk). But how about the velocity at the left face of the far left cell? Is that the reason why Flow-3D using real cells and boundary cells around them? By the way, when I asked a question about the calculated free surface in Flow-3D by VOF method, Jeff Burnham relpied that "the way FLOW-3D calculates the fluid free surface in sharp-interface problems uses special algorithms (TruVOF and FAVOR) so that the location of the free surface is accurately calculated independent of the mesh size". Does that mean the calculated free surface in Flow-3D is insensitive to mesh size? Since the definition of entrainment through NF values in the customization which I'm using is sensitive to the mesh size, I'm thinking if I can use another method to tracking the entrainment location. Thanks a lot! Yang |
September 10, 2010, 21:58 |
#6 | |
michael barkhudarov
Rep Power: 18 |
gfssssss |
How to limit a variable | ash | OpenFOAM Running, Solving & CFD | 1 | June 26, 2008 20:32 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 04:35 |
limit for a variable | Luis | CFX | 5 | February 12, 2008 05:55 |
Temperature went outside of its upper limit | Atit Koonsrisuk | CFX | 0 | January 8, 2004 11:43 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
