Home > Forums > Software User Forums > FLOW-3D
Radiation mechanism in FLOW-3D
Old   October 4, 2010, 07:38
Default Radiation mechanism in FLOW-3D
FRAN is on a distinguished road
I want to know if FLOW-3D calculates the radiation mechanism of thermal transfer. I mean the heat transfer between 2 solids at a different temperature. We see that you only can define an emissivity to void but not an absortivity.
Also we have done an example with a thermal shadowing area and a body heated at high temperature and it seems that there is not distance-heat radition transference
Thanks in advance
Vss
FRAN is offline   Reply With Quote
Old   October 4, 2010, 21:06
michael barkhudarov
MuxaB is on a distinguished road
you are right, the radiation model in flow-3d only accounts for fluxes from a surface to infinity. There is no model to model radiative heat exchange between two bodies.
MuxaB is offline   Reply With Quote
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
laminar flow mechanism kk FLUENT 4 February 16, 2007 16:35
How to change from mass flow to volume flow rate stanley FLUENT 1 February 2, 2007 06:44
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
