-   FLOW-3D (http://www.cfd-online.com/Forums/flow-3d/)
-   -   Beginner Problem (http://www.cfd-online.com/Forums/flow-3d/81725-beginner-problem.html)
Sly787 November 4, 2010 15:58
Beginner Problem
Hi All,
I'm italian and I'm an engineer who works in inkjet world. I'm developing a new piezoelectric printhead for printing on tiles and I need to simulate drop formation.
When I had to simulate pressure history and velocity history I used FLUENT and I model a 2d surface, so with axis-symmetry condition I can obtain a full developed structure.
For drop formation I think Flow-3d is better than FLUENT, so I'm trying to use it, but can I work in the same way?
Can I model a 2D surface for 1/2nozzle and use symmetry to have other 1/2? Or in general is possible to simulate 2D or 1D problem?
Because now I model 2D surface, but when I mesh it software crashes if try to use a 2D mesh. When a 3D mesh all is ok, but I want a 2D problem.
Thank You.
MuxaB November 4, 2010 23:57
yes, you should be able to run 1d and 2d problems and use symmetry in FLOW-3D. There are several examples of such modeling in the Examples directory in the installation.
What is the error message when it crashes?
Sly787 November 5, 2010 03:55
Nothing message.
Simply Win7 crashes and exits from program.
MuxaB November 6, 2010 20:40
Originally Posted by Sly787 (Post 282258)
Nothing message.
Have you talked to support? At what stage is it crashing, during pre-processing or some way into the simulation?
Sly787 November 7, 2010 05:37
It crashes after meshing when I begin to set-up boundary conditions. When I open boundary conditions window after model geometry and mesh.
I can't set any boundary conditions.
MuxaB November 7, 2010 13:03
Oh, so the GUI crashes as soon as you start setting up the boundary conditions, right? I have not heard of this problem. Have you reported it to support? Can you attach here the prepin file?
