November 4, 2010, 14:58 |
Beginner Problem
Rep Power: 15 |
Hi All,
I'm italian and I'm an engineer who works in inkjet world. I'm developing a new piezoelectric printhead for printing on tiles and I need to simulate drop formation. When I had to simulate pressure history and velocity history I used FLUENT and I model a 2d surface, so with axis-symmetry condition I can obtain a full developed structure. For drop formation I think Flow-3d is better than FLUENT, so I'm trying to use it, but can I work in the same way? Can I model a 2D surface for 1/2nozzle and use symmetry to have other 1/2? Or in general is possible to simulate 2D or 1D problem? Because now I model 2D surface, but when I mesh it software crashes if try to use a 2D mesh. When a 3D mesh all is ok, but I want a 2D problem. Thank You. |
November 4, 2010, 22:57 |
michael barkhudarov
Rep Power: 18 |
yes, you should be able to run 1d and 2d problems and use symmetry in FLOW-3D. There are several examples of such modeling in the Examples directory in the installation.
What is the error message when it crashes? |
November 5, 2010, 02:55 |
#3 | |
Rep Power: 15 |
Simply Win7 crashes and exits from program. |
November 6, 2010, 19:40 |
michael barkhudarov
Rep Power: 18 |
November 7, 2010, 04:37 |
#5 | |
Rep Power: 15 |
I can't set any boundary conditions. |
November 7, 2010, 12:03 |
michael barkhudarov
Rep Power: 18 |
Oh, so the GUI crashes as soon as you start setting up the boundary conditions, right? I have not heard of this problem. Have you reported it to support? Can you attach here the prepin file?
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Incoherent problem table in hollow-fiber spinning | Gianni | FLUENT | 0 | April 5, 2008 10:33 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
problem with using colocated code | Jack | Main CFD Forum | 0 | December 15, 2002 00:15 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
