-   FLOW-3D (http://www.cfd-online.com/Forums/flow-3d/)
-   -   mesh convergence (http://www.cfd-online.com/Forums/flow-3d/82360-mesh-convergence.html)
jiko November 24, 2010 09:29
mesh convergence
Hi, I am trying to simulate an oscillating GMO in still fluid. so far I 've been unable to get a mesh independence solution. I did modify the turbulence options to RNG with length scale of 7% of the turbulent region and got slightly better results but still not perfect.
any suggestion would be greatly appreciated. (do I need to switch on something in numerics)
Regards
jko
JBurnham November 24, 2010 14:24
Jiko - the solution is going to be mesh-dependent because the near-wall treatment of turbulent boundary effects (velocity and shear) are mesh-dependent. The cells nearest the wall or inclusive of wall apply a logarithmic-law-of-the-wall profile to iteratively determine the velocity profile. If the cells near the wall are too large, then the near wall velocity and shear will be underpredicted, and vice-versa. The FLOW-3D website has a hints&tips article and a tech-note that describe the phenomena and discuss how to account for it:
http://www.flow3d.com/resources/news...esolution.html
http://www.flow3d.com/pdfs/tn/FloSci-TN86.pdf
jiko November 29, 2010 06:26
Hi Jeff, Thanks allot for the tips and the related links.
there is one more thing that I would like to be commented on.
I do get a good mesh independece for a set of two meshes (say with sizes 0.005 and 0.007) now if I further reduce the cell size to 0.003 the solution, instead of a better agreement, differs (from the previous results of 0.006 and 0.008) by much greater extent.
thanks for your time.
jiko November 29, 2010 06:27
correction
I do get a good mesh independece for a set of two meshes (say with sizes 0.005 and 0.007) now if I further reduce the cell size to 0.003 the solution, instead of a better agreement, differs (from the previous results of 0.005 and 0.007) by much greater extent.
MuxaB November 30, 2010 00:37
What output are you using to gauge the mesh dependence?
jiko November 30, 2010 05:54
Hi Michael, good question! I am plotting the total x force (pressure+shear), as for now I am interested only in the x force. and GMO is moving with prescribed sinosoidal velocity in the x direction.
thanks for the consideration.
looking forward to your reply.
