November 24, 2010, 08:29 |
mesh convergence
jiko
Hi, I am trying to simulate an oscillating GMO in still fluid. so far I 've been unable to get a mesh independence solution. I did modify the turbulence options to RNG with length scale of 7% of the turbulent region and got slightly better results but still not perfect.
any suggestion would be greatly appreciated. (do I need to switch on something in numerics) Regards jko |
November 24, 2010, 13:24 |
Jeff Burnham
Jiko - the solution is going to be mesh-dependent because the near-wall treatment of turbulent boundary effects (velocity and shear) are mesh-dependent. The cells nearest the wall or inclusive of wall apply a logarithmic-law-of-the-wall profile to iteratively determine the velocity profile. If the cells near the wall are too large, then the near wall velocity and shear will be underpredicted, and vice-versa. The FLOW-3D website has a hints&tips article and a tech-note that describe the phenomena and discuss how to account for it:
http://www.flow3d.com/resources/news...esolution.html http://www.flow3d.com/pdfs/tn/FloSci-TN86.pdf |
November 29, 2010, 05:26 |
jiko
Hi Jeff, Thanks allot for the tips and the related links.
there is one more thing that I would like to be commented on. I do get a good mesh independece for a set of two meshes (say with sizes 0.005 and 0.007) now if I further reduce the cell size to 0.003 the solution, instead of a better agreement, differs (from the previous results of 0.006 and 0.008) by much greater extent. thanks for your time. |
November 29, 2010, 05:27 |
#4 | |
jiko
correction
November 29, 2010, 23:37 |
michael barkhudarov
Rep Power: 18 |
What output are you using to gauge the mesh dependence? |
November 30, 2010, 04:54 |
jiko
Hi Michael, good question! I am plotting the total x force (pressure+shear), as for now I am interested only in the x force. and GMO is moving with prescribed sinosoidal velocity in the x direction.
thanks for the consideration. looking forward to your reply. |
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel | colinB | OpenFOAM Meshing & Mesh Conversion | 14 | December 12, 2018 08:07 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
mesh quality and convergence | Ed Schaub | FLUENT | 2 | April 24, 2006 10:55 |
