Home > Forums > Software User Forums > FLOW-3D
6 DOF objects colliding with walls
Old   December 4, 2010, 03:04
Default 6 DOF objects colliding with walls
Ed Moses
edmoses is on a distinguished road
Hellow All,
My name is Ed Moses and I am new to Flow 3D (though I have CFD experience with other codes). I am setting up a problem involving 6 degrees of freedom objects freely moving with the flow in a confined space. The bodies are nearly neutrally buoyant and there is no free surface. What happens is the sometimes (not all the time) one of the bodies will penetrate the wall of the vessel and go outside the flow field alltogether. The confining vessel is defined as a component (from a .stl file) with given collision properties. Collision model is activated as well as gravity. The 6DOF bodies are also imported as separate components from .stl files and collision properties are defined for them.
Anybody can give me an idea what I did wrong to have these objects penetrate the solid walls of the confining vessel?
Many thanks and best regards,
Ed Moses
edmoses is offline   Reply With Quote
Old   December 5, 2010, 07:37
Yang Yue
therockyy is on a distinguished road
Does your .stl file has thin wall? Once I got the similar problem if the stl file has thin part while the mesh is not fine enough.
Yang
therockyy is offline   Reply With Quote
Old   December 5, 2010, 10:02
Ed Moses
Yang
Dear therockyy,
Many thanks for your swift answer. My .stl is actually the fluid domain (complement) and has zero thickness walls. I see the problem now and will change the .stl to be the actual solid, so that the wall will have a thickness.
Ed Moses
Old   December 7, 2010, 08:37
Angry 6 DOF objects colliding with walls
Boris Huber
BH2010 is on a distinguished road
The collision model does not work properly when objects collide very slowly - Flow Science knows that but it will be fixed somewhat later.
Greatings
BH2010 is offline   Reply With Quote
6dof, collision, confined flow
Problem with rhoSimpleFoam : exploding enthalpy and density at the walls david39 OpenFOAM Running, Solving & CFD 6 January 18, 2011 11:49
Heat loss through walls franzdrs Main CFD Forum 2 September 30, 2009 06:33
2 Domains share their walls...any interface ? KK CFX 2 February 7, 2008 16:34
The concept of DOF in fluid mechanics and CFD bearcat Main CFD Forum 8 May 27, 2007 18:02
thermal conditions of walls Stefan FLUENT 2 March 23, 2003 06:17
