Home > Forums > Software User Forums > FLOW-3D
limit in meshing and about restart
Old   July 2, 2011, 09:19
Default limit in meshing and about restart
ava
S.Elyasi
ava is on a distinguished road
hi
i have 2 question
1)is there limitation in mesh size ratio in directions of x,y,z????
2)can i stop the simulation of model and for example after 2 day continue the simulation of it?
what options in flow3d can do it?restart or another option?
please give a coplete explain about restart in flow3d
ava is offline   Reply With Quote
Old   July 5, 2011, 09:00
Mjoelnir is on a distinguished road
1) if you mean the size of the then, there is no limit.
if you mean the ratio of the length in each direction(how stretched the cells are) then i got no answer for you but the solver produce the best result with cubic cells
2) you can only continue a simulation with a restart simulation. Just look in the manual (press f1) it is explained pretty good
Mjoelnir is offline   Reply With Quote
Old   July 6, 2011, 00:46
Default ?
ava
S.Elyasi
Hi
Thank you very much.
may i have your ID for any question about this?
