Home > Forums > Software User Forums > FLOW-3D
Output velocity magnitude
Old   August 4, 2011, 00:31
Smile Output velocity magnitude
Marco S.
satellite_control is on a distinguished road
Flow 3D shows velocity magnitude when I analyze in 2D.
But when I try to make a Text output of the velocity magnitude data, I can just find x-velocity, y-velocity and z-velocity.
where can I find the velocity magnitude data to export it?
Should I change my settings in Model-Setup->Output?
My configurations are:
Restart data and history data and hydraulic data.
There is no klick on selected data.
Thank you for your help!
satellite_control is offline   Reply With Quote
Old   November 30, 2011, 19:07
michael barkhudarov
MuxaB is on a distinguished road
Velocity magnitude is not explicitly saved into the FLOW-3D data file. It is computed by the post-processor, so it is a derived quantity.
Text output does not have that option, but you can try the following:
1. create a 2d or 3d plot using velocity magnitude as the color variable.
2. after rendering, go back to Analyze and select Custom tab.
3. pick the file flsinp.tmp from the drop-down menu at the top and change the value of omode to -1.
4. click Render and select text for the output. It should pipe all quantities to a text window. I think (!) it should convert velocities to the magnitude.
MuxaB is offline   Reply With Quote
why the inlet velocity magnitude differrent from the value i initialize? eyuhock FLUENT 26 April 20, 2015 21:34
Questions about data output aki_yafuji OpenFOAM Running, Solving & CFD 3 September 9, 2010 01:59
how to compute relative velocity from absolute? spk Main CFD Forum 3 July 9, 2010 08:42
Gradient of the velocity magnitude anja OpenFOAM Pre-Processing 5 June 6, 2006 08:39
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
