-   FLOW-3D (http://www.cfd-online.com/Forums/flow-3d/)
-   -   Meshing & Geometry - issue with inner hollow tube rendering (http://www.cfd-online.com/Forums/flow-3d/96684-meshing-geometry-issue-inner-hollow-tube-rendering.html)
kavanaa1 January 29, 2012 18:59
1 Attachment(s)
Hi All,
I have a mould that contains a hollow ceramic tube inside into which metal fills from a funnel. When the metal exits the bottom of the tube it hits the bottom of the mould before reversing direction and filling up some cavities/castings attached to the mould wall. When I set the mould and funnel as a hole inside a solid cube and the ceramic tube as a solid in a separate component, the bottom of the funnel goes missing and the metal just spills into the mould, not via the ceramic tube. I've attached an image I hope explains the issue a bit more.
Can anyone suggest how I can achieve the metal filling the mould via the ceramic tube by being connected to the funnel.
Thanks a lot
melissa November 27, 2012 17:02
So the geometry is all boolean based-
So if you have a solid and subtract is will subtract that entire geometry from the solid.
Here is my suggestion:
Subtract the tube from solid mold along with cavity and overflows
Then as a new component add the tube back in.
