Home > Forums > Software User Forums > FLOW-3D
Measuring fluid depth
Old   February 16, 2012, 19:27
Default Measuring fluid depth
half rho vsquared
halfrhovsquared is on a distinguished road
How do I measure the depth of fluid at a specific location in a draining channel or tank? I want to measure fluid height along one line, just like a dipstick or float gauge would.
halfrhovsquared is offline   Reply With Quote
Old   February 17, 2012, 09:19
half rho vsquared
Ok, found it. For future reference for someone:
Model Setup - Output - Special Output - Hydraulic Data
Only works with free surface flows and z must be set up with positive in the vertical direction.
Old   February 17, 2012, 10:16
MC
melissa is on a distinguished road
History probes can be added before you run the simulation.
Depending on your version you will either have to enter them manually into the prepin file or through the GUI meshing & geometry.
You also have options in post-processing in 1-D and text output tab.
melissa is offline   Reply With Quote
Old   February 17, 2012, 14:46
half rho vsquared
Good info, thank you!
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Specifying fluid density sanjibdsharma OpenFOAM 2 February 22, 2011 08:55
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
fluid hot volume in fluid cold volume zahid FLUENT 4 June 1, 2002 09:11
