Home > Forums > Software User Forums > FLOW-3D
can I model a pump on FLOW-3D ?
Old   February 2, 2012, 08:52
Exclamation can I model a pump on FLOW-3D ?
hela maaloul
helamaaloul is on a distinguished road
I'm trying to model a small pool (1m* 0.46m*0.2m) with a closed circuit and a pump. But when I use a mass momentum sources to model the pump I realize an increase of the total quantity of water initially mentioned (because it generates a water flow) but what I want is to stabilize water level in the pool. How can I do that ?
helamaaloul is offline   Reply With Quote
Old   February 8, 2012, 17:39
Jeff Burnham
JBurnham is on a distinguished road
Use the 'fan and impeller' model. It's a type of phantom component that adds momentum to the fluid passing through it, and drops the pressure following a user-specified (linear approximation) pump curve. You can also add blade effects and other dynamics, but even the simplest form of it will do the job for moving liquid around a pumping system. It's described in the User Manual.
JBurnham is offline   Reply With Quote
modeling pump
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 10:34
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Cavitation model with non-isothermal flow pitisrisuk CFX 0 July 14, 2009 14:30
validating turbulence model on flow around a car Pedro CFX 1 February 20, 2008 16:32
Multiphase flow. Dispersed and free surface model Luis CFX 8 May 29, 2007 18:13
