-   FLOW-3D (http://www.cfd-online.com/Forums/flow-3d/)
-   -   how to generate STL files correspond to the topography?? (http://www.cfd-online.com/Forums/flow-3d/97850-how-generate-stl-files-correspond-topography.html)
ava February 27, 2012 09:29
hi
all dears
i have to work on a river bed with topographic variation
how can i generate STL files correspond to the topography in AUTOCAD?
can you help me?:confused:
melissa February 27, 2012 11:47
You can try the following:
  1. At the prompt type STLOUT
  2. Select objects
  3. Choose "Y" for Binary
  4. Choose Filename
But it is not necessary to have the topo as an stl in flow3d. You can open topo files in flow3d. See examples in flow3d there is one with a topo file.
Y_G April 15, 2012 01:05
Generate STL file from a Topography
First of all you have to make a surface of your topography in CIVIL 3D software. After that you have to extract the TIN surface of your topography.
Result is 3dFace object that you can save as DXF format.
Now you have to import your DXF file in to MATERIALISE MAGICS software.
In this software you can edit your stl format files.
It's good to know that the flow-3D can produce the topography by points of Topo. But the result is not very satisfactory.
me.ouda May 14, 2012 20:52
you can import the xyz file directly into flow 3d
farshid June 22, 2012 04:04
create topographic file
Originally Posted by ava (Post 346471)
hi
all dears
my dear
For create topographic file (surface) Use of the surveying software such as: Land Desktop, Inroad, SDRmap.(we know this file is ©).
So, for using in the flow-3D model:
Meshing geometry» subcomponent» advenced» Type: topographic file & File name: ©
usmanzafar21 November 19, 2012 01:42
how to measure velocity at u/s and d/s of dam
max0014 November 19, 2012 15:34
you can output x-, y- or z- velocity at any location from probe or 1-D sub-tab of Analyze tab in FLOW-3D.
