Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
solid-solid-liquid three phase flow in stirred tank
Old   June 12, 2013, 13:42
Default solid-solid-liquid three phase flow in stirred tank
Manjunath
manjunath is on a distinguished road
I am trying to simulate solid-liquid flows in a stirred tank. I was able to set up and simulate the case for two phase solid-liquid flow, 100 micrometer diameter solid particles (VF = 0.1) in water using both Mixture and Eulerian model.
I am interested in adding particles of different diameter (1000 micrometer dia, VF = 0.1) to the tank, essentially creating a three phase solid-solid-liquid flow. I am getting divergence error if I solve for the volume fraction equations, even if I start with a converged initial solution which is obtained by ignoring the volume fraction equations.
I am using MRF technique to model the impeller rotation and using mixture turbulence model. Any help on this issue is appreciated.
Thanks,
Manjunath
manjunath is offline   Reply With Quote
Divergence after change in mass flow rate in two phase flow meetsunilkale FLUENT 1 March 25, 2013 03:03
Two phase flow with condensation Sunnie FLUENT 0 May 31, 2009 10:02
What is the difference between liquid reactive flow and gas reactive flow? James Main CFD Forum 6 May 15, 2009 12:14
Multiphase flow problem icedou FLUENT 6 July 10, 2005 02:52
Flow patterns in a stirred tank Glenn Price Main CFD Forum 13 March 20, 1999 10:16
