June 5, 2013, 10:18 |
where is Reference Level
FHydro
Rep Power: 13 |
Hello.
I want to model a free surface channel. i am using "Open channel flow" option in fluent but when i am starting the solver and its done there is no any fluid into the model (there is just air). my question is: where is the reference level in defining pressure inlet and pressure outlet of channel. please see attached images thanks Last edited by flow_CH; June 6, 2013 at 04:43. |
June 5, 2013, 10:51 |
OJ
Rep Power: 20 |
Probably you haven't patched the volume fractions of water and air properly. Have a look at the VOF tutorail in FLUENT
OJ |
June 5, 2013, 11:11 |
#3 | |
FHydro
Rep Power: 13 |
i read all fluent user guide but i don't understand what the patch is? what parameters i should define in patch for open channel flows. I think my problem is in reference level. |
June 6, 2013, 06:44 |
OJ
Rep Power: 20 |
You need to mark the registers where the fluid exists, and during initialization, set the value for volume fraction for the registers as 1. It's only then that you will have two fluids with volume fractions 1 in different regions, separated by the interface.
OJ |
June 6, 2013, 09:29 |
FHydro
Rep Power: 13 |
i know that. my question is: where is reference level in defining free surface and bottom of channel in OPEN CHANNEL FLOW option.
June 6, 2013, 10:58 |
OJ
Rep Power: 20 |
Well the reference level should be any arbitrary point, probably determined by the origin of your geometry. Just make sure that you give appropriate signs of the levels such that:
"free surface level" - "bottom level" = height of open channel flow Does this help? OJ |
Display Modes | |
Second Derivative Zero - Boundary Condition | fu-ki-pa | OpenFOAM | 11 | March 27, 2021 04:28 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
