April 12, 2013, 01:06 |
multiphase model
tang
hi,
i am not sure whether i need to turn on multiphase model..and what type of multiphase should i choose? Mixture?? My condition is water jet towards the sand domain..and hitting towards the wall (erosion) which surrounded with sand domain. |
April 12, 2013, 02:23 |
Rick
Rep Power: 26 |
You can use mixture model if sand volume fraction is <0.1; you can also use dpm model to model erosion, there's a fluent tutorial about erosion in 180 degree U-bend.
Daniele |
April 12, 2013, 02:39 |
tang
thanks for repying..
So does my setting correctly as shown below? phases Phase 1 = water liquid phase 2 = sand -granular cell zone condition liquid-solid = porous zone - material = mixture solid = mixture Regard on cell zone condition is only available only one type (mixture)?? |
April 12, 2013, 02:45 |
Rick
Rep Power: 26 |
Sorry, I haven't read well your problem, sand is not in the water which erodes some surface, but a jet of water erodes a sand surface..I'm not sure about how approaching this type of problem, I think it is more appropriate to use eulerian model; at time=0 patch solid zone with sand volume fraction=1
Daniele |
April 12, 2013, 02:48 |
tang
Anyways, thank for your attention!!
May 29, 2013, 02:40 |
tang
i'm confuse on the Eulerian model on eulerian parameter.
What the different dense discrete phase model and multi fluid vof model?? My sand domain should treated as fluid or discrete phase?? |
June 6, 2013, 11:15 |
OJ
Rep Power: 20 |
DDPM involves langrangian tracking of the particles in dispersed material, and it is different from DPM in that, DPM doesn't take into account the effect of volume fraction of the discrete phase in mass/momentum equations. DDPM does take into account.
VOF is used when the volume fraction of the discrete phase is locally very large, such that there is a distinct interface betwee the two phases, eg, large bubbles in slug flow. If you are specifying sand domain as porous medium, how are you taking into account the erosion? Can you post an image of your domain and boundary conditions? OJ |
June 6, 2013, 12:16 |
tang
hi,
From the picture, the three hole(red) is treated as water jet inlet; my outlet, is the top surface of the sand domain. And the green pipe is the cylinder wall (green). i'm thinking on eulerian model is the most suitable for my condition, and treated my sand as granular flow, packed bed for study on erosion rate of the wall. I patch my sand domain initial volume faction as 1. Are you agree with my setting?? Problems?? 1) what turbulent viscosity and intensity should i set?? For this condition, as water flow in sand domain, it may be not so turbulent in sand domain. 2) Can i set the wall pipe material?? 3) Can i just assume the wall boundary condition as no slip condition. |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 25, 2009 23:27 |
mass balance problem in multiphase model | mdsanij1 | FLUENT | 0 | July 28, 2009 16:01 |
Multiphase model and species transport | Reginaldo Cotto | FLUENT | 0 | August 29, 2006 20:36 |
multiphase model & separation | naser | FLUENT | 5 | June 9, 2006 06:12 |
