Vessel filled of 50% by liquid and 50% by vapor
1 Attachment(s)
Hi everyone,
i've a problem when i try to read the mesh generated in ICEM 14 in a parallel processing. To set the problem in icem(vessel partially filled of liquid) i create two part (liquid below and vapor above) and an interface but when i go in fluent and i try to read the mesh appears the following message: Error: Failed in Fill_Domain. and then aborted due to a critical error. I've already try to read the mesh with serial processing but with no result. Can someone help me? David P.s: i've attached the mesh |
Zacfranki, why not use the VOF model with which you can simply do the job.
because if i don't define two parts in icem, but i only use the vof in fluent it won't understand the separation between the liquid and vapor region, it doesn't see the interface
