Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Open channel flow with submerged outlet
Old   September 30, 2013, 08:04
Exclamation Open channel flow with submerged outlet
Fonta is on a distinguished road
Hi everybody.
I'm trying to simulate an open channel condition (VOF, 2 phase, air and water, ecc.).
The first part of the channel works in free flow condition. The second part is a closed submerged circular conduit.
There's no way to make it converge. I've tried almost every boundary conditions, without success.
I've activated the "open channel" option in the model, and set a mass flow inlet as a inlet boundary condition, with "open channel" flag.
As outlet condition I've used a pressure outlet, setting the expected pressure at the end of the conduit.
In the open channel part, the sky is set as pressure outlet, with pressure=0 (atmosphere).
So the air mass flow inlet should exit through the sky, while the water should go by the conduit.
As say, no way to make it converge.
Any suggestion?
Fonta is offline   Reply With Quote
Complex problem: Open Channel Flow lett FLUENT 18 November 10, 2018 18:30
Review: Reversed flow CRT FLUENT 1 May 7, 2018 05:36
Open channel flow with stratified flow k.baker FLUENT 0 December 3, 2010 03:30
Pressure outlet in two-phase flow in horizontal 2D channel AlmostSurelyRob Main CFD Forum 0 November 17, 2010 07:32
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
