The compiling mistake for a user-defined mixing law for density
Hi everyone,
I'm getting the following mistake: Copied C:\Users\linxinti\Desktop\XL\heattransfer-baser/C:\Users\linxinti\Desktop\XL\heattransfer-baser\co_ideal1.c to libc3\src Copied C:\Users\linxinti\Desktop\XL\heattransfer-baser/C:\Users\linxinti\Desktop\XL\heattransfer-baser\rhochange1.c to libc3\src Creating user_nt.udf file for 2ddp_host ... (system "copy "C:\PROGRA~1\ANSYSI~1\v145\fluent"\fluent14.5.0\sr c\makefile_nt.udf "libc3\win64\2ddp_host\makefile" ") 1 file(s) copied. (chdir "libc3")() (chdir "win64\2ddp_host")() # Generating ud_io1.h co_ideal1.c rhochange1.c ..\..\src\rhochange1.c(13) : error C2143: syntax error : missing ';' before '{' Generating Code... Creating user_nt.udf file for 2ddp_node ... (system "copy "C:\PROGRA~1\ANSYSI~1\v145\fluent"\fluent14.5.0\sr c\makefile_nt.udf "libc3\win64\2ddp_node\makefile" ") 1 file(s) copied. (chdir "libc3")() (chdir "win64\2ddp_node")() # Generating ud_io1.h co_ideal1.c rhochange1.c ..\..\src\rhochange1.c(13) : error C2143: syntax error : missing ';' before '{' Generating Code... Done. Opening library "C:\Users\linxinti\Desktop\XL\heattransfer-baser\libc3"... Primitive Error at Node 0: The UDF library you are trying to load (libc3) is not compiled for parallel use on the current platform (win64). The operation completed successfully. C:\Users\linxinti\Desktop\XL\heattransfer-baser\libc3\win64\2ddp_node\libudf.dll Error: The UDF library you are trying to load (libc3) is not compiled for parallel use on the current platform (win64). The operation completed successfully. However I don't find the mistake in my code, which is as follows: #include "udf.h" DEFINE_PROPERTY(rhochange1,c,t) { Material *sp; Property *prop; real sum = 0.; real rho; int i; mixture_species_loop_c(THREAD_MATERIAL(t),sp,i) { prop = (MATERIAL_PROPERTY(sp)); rho = generic_property(c,t,prop,PROP_rho,C_T(c,t)); sum += C_YI(c,t,i)/rho; } return 1./sum; } Can anyone help me about this? Thanks a lot! Problem solved. mixture_species_loop_c is not correct. Should be mixture_species_loop |
mixture_species_loop_c maybe change by mixture_species_loop??
