Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
The compiling mistake for a user-defined mixing law for density
Old   January 26, 2014, 12:34
Unhappy The compiling mistake for a user-defined mixing law for density
Michigan
lxlxlxt is an unknown quantity at this point
Hi everyone,
I'm getting the following mistake:
Copied C:\Users\linxinti\Desktop\XL\heattransfer-baser/C:\Users\linxinti\Desktop\XL\heattransfer-baser\co_ideal1.c to libc3\src
Copied C:\Users\linxinti\Desktop\XL\heattransfer-baser/C:\Users\linxinti\Desktop\XL\heattransfer-baser\rhochange1.c to libc3\src
Creating user_nt.udf file for 2ddp_host ...
(system "copy "C:\PROGRA~1\ANSYSI~1\v145\fluent"\fluent14.5.0\sr c\makefile_nt.udf "libc3\win64\2ddp_host\makefile" ")
1 file(s) copied.
(chdir "libc3")()
(chdir "win64\2ddp_host")()
# Generating ud_io1.h
co_ideal1.c
rhochange1.c
..\..\src\rhochange1.c(13) : error C2143: syntax error : missing ';' before '{'
Generating Code...
Creating user_nt.udf file for 2ddp_node ...
(system "copy "C:\PROGRA~1\ANSYSI~1\v145\fluent"\fluent14.5.0\sr c\makefile_nt.udf "libc3\win64\2ddp_node\makefile" ")
1 file(s) copied.
(chdir "libc3")()
(chdir "win64\2ddp_node")()
co_ideal1.c
rhochange1.c
Generating Code...
Done.
Opening library "C:\Users\linxinti\Desktop\XL\heattransfer-baser\libc3"...
Primitive Error at Node 0: The UDF library you are trying to load (libc3) is not compiled for parallel use on the current platform (win64).
The operation completed successfully.
C:\Users\linxinti\Desktop\XL\heattransfer-baser\libc3\win64\2ddp_node\libudf.dll
Error: The UDF library you are trying to load (libc3) is not compiled for parallel use on the current platform (win64).
However I don't find the mistake in my code, which is as follows:
#include "udf.h"
DEFINE_PROPERTY(rhochange1,c,t)
Material *sp;
Property *prop;
real sum = 0.;
real rho;
int i;
mixture_species_loop_c(THREAD_MATERIAL(t),sp,i)
prop = (MATERIAL_PROPERTY(sp));
rho = generic_property(c,t,prop,PROP_rho,C_T(c,t));
sum += C_YI(c,t,i)/rho;
return 1./sum;
Can anyone help me about this? Thanks a lot!
Problem solved. mixture_species_loop_c is not correct. Should be mixture_species_loop
lxlxlxt is offline   Reply With Quote
Old   December 9, 2014, 23:44
wenjue
wenjue is on a distinguished road
mixture_species_loop_c maybe change by mixture_species_loop??
wenjue is offline   Reply With Quote
compile, multiphase, udf, vof
[General] Paraview User defined view prapanj ParaView 3 January 3, 2014 20:54
user defined sourcen term xck1986 CFX 1 July 8, 2010 08:35
user defined turbulence model manuutin STAR-CD 5 October 14, 2009 05:29
UDF - Derivatives for User Defined Memory Variable Sandilya Garimella FLUENT 0 January 14, 2008 10:39
Error when compiling user fortran Mads Bang CFX 1 October 8, 2002 11:47
