Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
2D VOF Droplet evaporation model. Multi-component problem
Old   February 28, 2014, 10:36
Default 2D VOF Droplet evaporation model. Multi-component problem
Nick
nb92 is on a distinguished road
I am using Fluent 14 for a 2D VOF simulation, modelling a droplet impact on a heated surface.
I consider the domain to be a cylinder which contains air. The temperature of the air and the cylinder base are equal. The droplet is a solution of a polymer dissolved in water. It enters the system at ambient temperature and as it falls, the water component starts to evaporate. The droplet impacts the cylinder base and spreads; it continues to evaporate whilst on the surface.
The droplet solution has been added to the initial mesh using a region adaption.
I need to account for water evaporation from the droplet due to heat transfer between the droplet and air and the air and the cylinder base.
I have simulated the impact without mass and heat transfer to date. Attached is a jpeg showing the domain with a droplet of the solution. Please see 'Annotated droplet phase image.jpg'
So could anyone tell me how to account for the droplet containing 2 components (water and polymer) in order to model evaporation of water from the solution?
If you need any more information please ask.
Regards
Nick
nb92 is offline   Reply With Quote
droplet, evaporation, fluent, heat and mass transfer, vof
How to study pressure drop of continous phase in VOF model sajeesh FLUENT 4 February 5, 2014 22:01
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
UDF: how to identify interface in VOF model process.abhi Fluent UDF and Scheme Programming 1 April 19, 2012 02:11
question about Heat transfer between two phases with VOF model sooroo3 FLUENT 0 February 15, 2011 03:24
problem with vof model nadav wetzler FLUENT 1 February 26, 2008 02:09
