Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
problem about DPM of a valve inside flowfield
Old   March 9, 2014, 23:01
Smile problem about DPM of a valve inside flowfield
chang is on a distinguished road
I want to calculate the particle trajectory in a valve. I have got the converger result of gas flow field inside. But when I added DPM into it, some error happened. Error: Floating point error: invalid number.
Are there some special issue to be noticed when using DPM? The point Properties: diameter 0.0001m, Temp 500K, velocity 1m/s, total flow rate 0.1kg/s. The max NO. of steps is 1000. Courant number is 0.1. So what's the problem may be?
Thanks a lot
chang is offline   Reply With Quote
dpm, error, invalid number
DPM simulation convergence problem gemini FLUENT 2 May 22, 2012 01:41
Simulation of air flow inside valve - FSI? Help! farianka Main CFD Forum 0 April 17, 2011 16:30
DPM model problem wwa FLUENT 7 May 4, 2010 09:26
problem about DPM of cyclone separator simulation jason FLUENT 4 November 12, 2007 03:15
A problem in valve analysis zhpan Siemens 1 February 22, 2004 21:41
