problem about DPM of a valve inside flowfield |
March 9, 2014, 23:01 |
Rep Power: 12 |
I want to calculate the particle trajectory in a valve. I have got the converger result of gas flow field inside. But when I added DPM into it, some error happened. Error: Floating point error: invalid number.
Are there some special issue to be noticed when using DPM? The point Properties: diameter 0.0001m, Temp 500K, velocity 1m/s, total flow rate 0.1kg/s. The max NO. of steps is 1000. Courant number is 0.1. So what's the problem may be? Thanks a lot |
dpm, error, invalid number |
DPM simulation convergence problem | gemini | FLUENT | 2 | May 22, 2012 01:41 |
Simulation of air flow inside valve - FSI? Help! | farianka | Main CFD Forum | 0 | April 17, 2011 16:30 |
DPM model problem | wwa | FLUENT | 7 | May 4, 2010 09:26 |
problem about DPM of cyclone separator simulation | jason | FLUENT | 4 | November 12, 2007 03:15 |
A problem in valve analysis | zhpan | Siemens | 1 | February 22, 2004 21:41 |
