April 18, 2014, 16:28 |
brazing (welding) in fluent
Ali Kiani
Rep Power: 12 |
Hi CFD friends, I’m quite new in fluent.
I am working on a CFD problem and I want to simulate brazing in Fluent. 2 parts and 1 filler should be brazed to each other by using a single shot LASER beam. (See the schematic figure for this procedure) As I mentioned, I am an amateur fluent user and I need step by step advises about process of simulation, suitable simplification, etc. I would give more detailed info, if needed. There is a tight dead line for solving this problem. I am looking forward to your reply. By the way I tried vof coupled with solidification and melting but I don’t know it is good for simulating this problem or not! Thanks & regards. |
brazing, filler metal welding, solidification/melting |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 06:22 |
Alias problem when starting FLUENT from command line | batch_error | FLUENT | 0 | May 24, 2012 08:20 |
Fluent 12.0 is worst then Fluent 6.2 | herntan | FLUENT | 5 | December 14, 2009 02:57 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 16:48 |
