May 5, 2014, 08:50 |
Melting model in fluent
I am simulating melting of paraffin wax in an enclosure with heat supplied from bottom (VOF active), all other walls adiabatic. Temperature, density and liquid fraction contours are as intended but i am getting velocity in solid regions and even in liquid region velocity is messed up. I am using viscosity and density functions as udf and gravity is turned on.
I would be grateful if someone could suggest the possible solution. Please help. Thanks |
May 21, 2014, 09:58 |
Nils G
so far you described your problem very briefly, therefore I might miss some important details. What directly comes to my mind is that you might have a density that is temperature dependent in the solid region. IMHO this does not work / cannot work / should not work. The solidification / melting module in FLUENT tries to eliminate all velocities using brute force. But Continuity is more important. If the density changes (maybe decreases during heating), the solid will "spread out" in order to conserve the mass. In reality the shape would change, so your mesh should change to compensate that error. But as you mesh is not changing I strongly recommend using a constant density in the solid region. Best regards Nils |
May 22, 2014, 03:28 |
#3 | |
Hi I agree with Nils. I just have an addition to make. With constant density you will not have any buoyancy, so consider using the bousinesq approximation. I think there could be different approaches, too. For example you could try to integrate the density change in the melting zone and assign an appropriate velocity to the solid zone to change the shape of the solid zone. Regards |
May 22, 2014, 03:44 |
Nils G
I think the bousinesq approximation "beer" suggested might work for you. If you got inlets that are able to compensate the increasing density, then I think you should be totally fine using a temperature dependent density in the liquid region. But, as I mentioned before, just use a constant density in the solid region. Regards Nils Last edited by siegertyp; May 22, 2014 at 03:44. Reason: forgot regards |
fluent, melting, multiphase, vof |
Seeking Macroscopic Particle Model in Fluent | bzhang7 | FLUENT | 3 | June 25, 2022 17:54 |
How to create a 3Ds Car Model importing to FLUENT? | spysunny | Main CFD Forum | 1 | January 10, 2012 23:40 |
Why is Fluent unable to deal with my model at the micron scale? | dixylo | FLUENT | 4 | December 8, 2011 23:39 |
help:Implementation of Glass Batch Melting Model | chen | FLUENT | 0 | March 7, 2005 20:42 |
Covert Star-CD model to FLUENT | Lam | Siemens | 6 | June 24, 2003 20:21 |
