How can i check that my UDF is being used in fluent istead of its internal data
Dear all
I have written a UDF of volumetric reaction rate and hooked it in fluent. i want to know that is fluent using my UDF or the data i have given by user interface in material options. and i also want to know that can i use " relax to chemical equilibrium" along with UDF in fluent. Thanks in advance for your time and concern. |
I think you can add to your udf some i/o functions, such as printf and verify from the console (a sort of debug)..
But why fluent shouldn't use your options/udf?:confused: Daniele |
thanks buddy for help
actually first i hook the UDF and after some iterations unhook it. there is no effect. but when i change the data , in place of which this udf is being used, in fluent user interface effect came into pic. thatswhy i was confused that does this usf is being used or not. by the way the function that you are talking about, cna you describe it a bit deep??? |
Check this:
http://hpce.iitm.ac.in/website/Manua...df/node260.htm You can place some printf inside your udf to see values which fluent is using during the simulation. |
thanks man thanks a lot for the link. i used Message built in macro instead of printf . it is working .. thanks again
