How to get the total pressure in the UDF?
Old   September 12, 2012, 05:50
Default How to get the total pressure in the UDF?
Zhi-Gang Zhai
zgzhai is on a distinguished road
Hello all:
My case is incompressible single phase flow, and I want to get the total pressure and static pressure of some nodes. But the C_P could only get the static pressure, but how to get the total pressure in the UDF? Thank you very much.
BTW: i search a very old thread that said the fluent interior data structure. The total pressure is the 'derived' term, not the 'variable'. So it can not be got , should be calculated by 'total pressure = static pressure + operation pressure + 0.5*rho*v*v '. but I find the true case is not like this. I use the PLOT to print out the total pressure, dynamic pressure and static pressure. The total pressure from the PLOT is bigger than the calculated total pressure with the above formula. I guess maybe there is a coefficient before the '0.5*rho*v*v' .
zgzhai is offline   Reply With Quote
Old   September 12, 2012, 06:02
ghost82's Avatar
Rick
ghost82 will become famous soon enough
have you read this thread?
http://www.cfd-online.com/Forums/flu...-pressure.html
ghost82 is offline   Reply With Quote
Old   September 12, 2012, 06:15
Zhi-Gang Zhai
thanks to ghost82. I have read this thread. But I think the conclusion is not clear. if total pressure = static pressure + operation pressure + dynamic pressure, my question still exists . Thank you again.
Old   September 24, 2018, 16:12
Default Hydrostatic pressure
dan
deenriqu is on a distinguished road
Im not sure if this is the solution to your question, but technically,
total pressure = static + operating + dynamic + hydrostatic
The hydrostatic term may be influencing your solution if you gravity on
deenriqu is offline   Reply With Quote
Dynamic pressure from the total pressure specified saisanthoshm88 CFX 1 August 9, 2012 06:13
Total Pressure BC or Porous Media? khoopes FLUENT 0 August 2, 2012 12:24
Total Pressure problem in a duct anveshkadimi FLUENT 0 July 20, 2012 13:19
Total pressure in CFX famarcfd CFX 0 June 17, 2011 10:33
total pressure in CFX Atit Koonsrisuk CFX 0 January 1, 2005 05:46
